The output cards with OW in the code are relay types and will handle AC voltages . I use them quite often for 24v ac . I normally use 24v dc for the inputs , however if you must use 24 vac for the inputs , you could try a resistor , diode in series with a 24v zener diode/capacitor/resistor in parallel to ground . Take the input to a 24v dc card from above the zener . A bit cumbersome , but it will do the job .
Paul
Paul
