1734 VHSC 24V dc Problem with incoming frequency
acerbic
Nov 2008
cardiff
Hello people,
I have a query hope u'll help me out with this...
I m using 1734 VHSC 24vdc module with Devicenet and Slc 5/05 processor.
I am using VHSC for an underspeed proxy with 2000 HZ switching frequency by following Rate Measurement Mode as i am much more concern with the incoming frequency. Its been a week and i have tried almost every best option to get the frquency but still no joy yet..:mad:
The card is working perfectly fine , i can see the indication of Yellow light when ever any event occurs , wiring is perfect i can see 24 Vdc across channel A.
And i can see he data indicator C1 and C2 working just as it is defined in the manual..
Present Channel Data through counter state are working fine.
But accumalated count that is the return or incoming frequency is not changing at all .
On the manual it clearly says that read data is in actual a return frequency , but its not making any sense to me because the card itself is intellignet enough to compute the actuation and return the value in stored channel data but the value remains on ZERo.
If somebody could help me out that how shall i get the incoming frequency ,do i ahve to change something in configuration
cheers
Adi
Hi all, Using a 1734-VHSC for the first time (the 24V version). I think I have the theory of how to make it do what I want down, but it would...
2,028
Looking at installing point io, with a 1734-AENTR communications adapter and ten 1734-IT2L modules. In IAB it installs a 1734-EP24DC after every...
75
Hi everyone, new to forum. Since very long time i having issue with 1734-AENT module, after some period of time its keep stuck in error (simmilar...
19
760
I am trying to use the 4-20 mA signals from a device whose user manual says that it outputs "isolated 4-20 mA". I only have spare PLC inputs in a...
253
Hello The plant is running and there is no shutdown nowadays therefore I can add 1734- AENTR and its card while PLC is in Run? I do not wanna...
361
