1745-pcc-usb
I think in windows you can reserve COM1 so other devices will skip it, and let the newer smarter stuff use other COM numbers.
Hi Paul,
The reason I have to do this is to test the cables... serial and USB so I have to change the configure a lot, but I would like to give it to my customers
Mark
Okay, my laptop icon Target field is:
"C:\Program FIles\DosBox-0.72\dosbox.exe" -conf"C:\Program Files\DosBox-0.72\dosbox.conf"
My dosbox.conf file has the mods required to use the serial port (serial1=directserial realport:com1). This may be different if you're using an after market device with a USB port.
Then at the end of the dosbox.conf file I added:
[autoexec]
# Lines in this section will be run at startup.
mount s: c:\slc-150
s:
pcis
So, when I double click the icon, DOS box fires up with its config file which sets it up for use with a real serial port (in my case) and then mounts the folder "C:\SLC-150" as the s: drive, and starts PCIS.
Hope this helps.
Paul
Hello All, I am attempting to upload from a SLC 100. I know the controller is good because it is still in operation. I know the programming port...
3,454
i located the sw on the ab site but i get an error. i think because the sw i down loaded is not actived. i could not locate a PCIS comm sw for the...
1,968
Looking for a troubleshooting manual for the above PLC controller. So far I have found this one which is of no help...
5,527
I have an Allen Bradley SLC150 1745-LP152. What cable and software do I need to be able to download, edit, etc, the program? Is this possible...
5,085
Hey Crew, I know this has been knocked to death but I figure the quickest way to an answer is to ask the question again. I'm looking for a...
2,467
