1746-NI4 card blowing with 4-20mA signal
Bill Brasky
Jan 2006
Burlington
Hello,
Using a 1746-NI4 card for a 4-20mA signal.
My 4-20mA signal coming out of my unit is providing the power for the loop. Does this NI4 card also provide the power for the loop? I've blown 2 cards so far. Runs for a little while then goes out on me. I've hooked the 4-20mA signal to other hardware and works just fine but just seems to be blowing this card. The reciver that is providing the 4-20mA output can drive a load of 0-1150 ohms and the card is 250ohms industry standard I think.
Hoep someone has some ideas.
We usually supply an external 24Vdc to the loop; I don’t think the input card can provide the power.
[font=&quot][/font]
Using the 1746-NI4 as 4 Analogue inputs, all channels set to voltage in. I am presently only going to use Channel 1. Do I need to link out all...
2,253
Hello all. I have a 1746-NI4/B and I would like to get a cheap temerature module which I could use. I have found this on ebay...
2,608
I have a 7 -slot rack with SLC5/05 1747-L552 Processor. I have configured the inputs on slot 3 as I:3.0 I:3.1 I3:2 I3.3 and have tried different...
1,345
Is it really 0V input? You actually have a signal source hooked up to the input terminals? What does it read if you short the input terminals? Is...
3,043
G'day lads, We are using an Allen Bradley PLC slc5/03 with an analog input module 1746 ni4. we have a sensor with a response rate of 250ms. in...
3,145
