1746-no4v analog configuration
RickParrot
Nov 2015
Iowa
68
Hello, I am trying to configure the channels on a 1746-no4v card. I just did a 1746 ni8 using the Adv Config button. RSlogix threw in a rung of logic with a status bit and a COP instruction.
My attempts to do the same with the 1746-no4v have failed. This is a class 1 card.
Manual isn't helping.
Help!
controls engineer
You're right. I found out the hard way.... on my own. Manual makes it look like you have to configure it. So does RSLogix.
Thanks anyway. I will have more questions in the future I'm sure.
First here is the basic overview of the setup. We have a NO4V card that has a A-B Ultra and also two basic DC drives. Both are getting a 0-10v...
2,931
have a machine with a slc 1746-no4v analog card. Looked in the manual , and from 0-10v, it says that the raw value is 0- 32764. If i place a raw...
2,396
Hi, Just want to ask those experience user, do I need BT for 1746-NO4V or any 4 channel analog module for slc 500 in a RIO setup using 1-slot...
1,621
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
172
I had a 1746-HSCE go suspected bad. have to swap the card in the morning. Other than dip switch settings is there any configuration to do?
1,028
