1746-no4v - i am brain dead, having one of those days
irondesk40
Jan 2008
nc
630
have a machine with a slc 1746-no4v analog card.
Looked in the manual , and from 0-10v, it says that the raw value is 0- 32764.
If i place a raw value of 16382, i thought i would get 5vdc out, but i measure 5.704 volts.
What am i doing dumb?
Thanks for advice.
Finally found the problem. A technician in the plant had tried to go in and modify the program.
I was called out due to fact that a inverter used to control feeding fabric was no longer running the correct speed.
The reason was that the technician on a off shift had went in and tried to modify a piece of code to control the analog output.
So basically, the analog output was getting a value to run from two different locations at the same time.
Was in a big hurry, but learned a valuable lesson.
From now on first thing I will do is do a search for the output in question and make sure it is not being turned on from multiple locations. Should have known better, but was in a hurry and not thinking.
Hello, I am trying to configure the channels on a 1746-no4v card. I just did a 1746 ni8 using the Adv Config button. RSlogix threw in a rung of...
2,070
First here is the basic overview of the setup. We have a NO4V card that has a A-B Ultra and also two basic DC drives. Both are getting a 0-10v...
2,928
Hi, Just want to ask those experience user, do I need BT for 1746-NO4V or any 4 channel analog module for slc 500 in a RIO setup using 1-slot...
1,619
Hi, having some issues with scalings (SCP commands) with some Vegapuls 65 guided wave radar level transmitters. I've set the min/max in the...
146
I had a 1746-HSCE go suspected bad. have to swap the card in the morning. Other than dip switch settings is there any configuration to do?
1,027
