I have a 1747-L-20A. The inputs have the common labeled as common and are tied to gether internally. The inputs themselves have 2 diodes opposed. Can the line voltage be connected to the commons and the switches be used as a sink of sorts if you will. It would be much easier to run a common wire to the switches on the inputs than run 120v to them. It would also mean that if one shorted to ground the only result would be that the input would turn on which in my application would be ok. I'm using this on a wood furnace and would prefer not having to have any 120V near the flue and would prefer that the wires if they did short out simply turn the input on. By default the inputs here would only indicate overheat and shut the furnace down as well as turn the room air blower on.Also after so many minutes of the blower on and over heat in stack and plenum an alarm will come on.
