1747-L20A Question
draganjr
Nov 2005
Texas
I am not new to PLCs but new to old PLCs. My company just got this machine in from an unknown company using the 1747-L20A SLC 500.
My question is how do I know which RSLogix software it is using?
Thank you
David
That's an old "fixed SLC-500" controller.
The old DOS-based "APS" and "AI-500" software packages from Allen-Bradley and ICOM software, respectively, were used to program these before Windows came around.
The modern software that can still program them is called RSLogix 500.
The jack on the front of the controller is a DH-485 network port. The best interface to that port is a 1747-UIC USB/DH485 interface.
Although that jack looks like Ethernet, DO NOT plug an Ethernet jack into it. It has 24V DC on one of the pins and will smoke an Ethernet port.
There were 2 or 3 versions of the SLC software before RSLogix500. However, a current version of RSLogix should be backward-compatible for your SLC 5/00.
Edit: Too slow, too stiff.
We got it. Hooked it up to the 1747 PIC and installed the drivers and uploaded the program with 500. All is good.
Thank you for the fast replies.
Hi Ken,
I have same slc 500 1747-L20A model, but i do not have software to program it. is anyway i can get it as free to play with it?
thanks
Hi I have a 1747-L20A Fixed PLC and I want to know what cable I can use to program it. I am also looking for the cable pinout so I can make it...
3,019
I have a 1747-L-20A. The inputs have the common labeled as common and are tied to gether internally. The inputs themselves have 2 diodes opposed...
2,479
hello I am getting a 57h fault - Specialty I/O module has not responded to a lock shared memory command within the required limit. Fault randomly...
100
We are in the process of upgrading a controls system. The existing system is a SLC500 with some IO cards and a 1747-SDN module communicating to a...
563
se me desprendieron los cables del cable usb quiero soldarlos pero no se como van los cables si alquien me pudiera proporcionar una foto o como...
412
