1747 PIC to USB 2.0?
zqew05
Jun 2003
Alabama
110
Fellas,
I have this new laptop that do not have a serial port. I'm new to PLC's, please tell me what to do to connect the PIC to A USB 2.0 on this new laptop. Will I have to use my old laptop, w/c has a serial port? THANKS
I've run into the same problem as you. The screen is going out on my old laptop so I had to buy a new one. When reviewing laptops online, I could've sworn that the new one I got had a serial port. But last night, I was plugging in my USB floppy drive and noticed that it did not in fact have a serial port.
This evening I purchased a USB to serial cable at Radio Shack for $39.00. I'm going to test it out tomorrow and see how it goes.
The documentation that came with the cable states that it fully supports RS-232 for modems, PDAs, cameras and label printers, etc. so I'm hoping all goes well.
If I'm successful, I'll let you know.
Estevon said:
The documentation that came with the cable states that it fully supports RS-232 for modems, PDAs, cameras and label printers, etc...
Sorry, but the "etc..." does NOT include the 1747-PIC... :(
You may want to check out THIS RECENT THREAD regarding USB to serial adapters.
beerchug
-Eric
Reiteration
I've been through this topic lots of times and I have save you the wondering.
A USB/RS232 converter will not work with a 1747-PIC or 1761-NET-AIC.
USB/RS232 converters work well with DF1 and DeviceNet (1770-KFD) drivers in RSLinx, but not with the DH485 driver.
I just got my hands on a 1747-UIC USB/DH485 converter last night and I plan on testing it out with SLC-5/02, /03, /04, MicroLogix 1000, and PanelView terminals soon. The cost of that device is comparable to the 1747-PIC, and I hear that A-B has the initial production run glitches worked out (which one of our Forum members suffered through). I'll check the S/N on the unit I got to see if it's from the first shipmet lot.
-Eric
Hehe.
Well, the cable was only 39 bucks. If it doesn't work, I'll just pick up the 1747-UIC. No biggie :D
You didn't waste $39, Estevon. Your USB to Serial adapter WILL work with other stuff!... :nodi:
beerchug
-Eric
I just was issued a new computer that doesn't have a serial port. There are several things that I need a serial port for, but I'm anticipating...
2,153
Does any one have a converter that works...Want to use with IBM Windows98...CompactXP...MacBook...Mac OS X version 10.5.2...thanks...bds
4,368
Is there no compatible solution for this? I feel like I am in the stone ages here. Does AB think comp manufacturers are going to start putting...
29
9,604
G'day all. I'm a PLC student and have got hold of a SLC500 system with a 1746-L532 cpu. I am told that the interface convertor will allow my...
9,775
good afternoon all I had to pull out the old 1747-pic module my question it has a 25 pin connection I need to go to a 9 pin connection do pin 2...
1,597
