Only have USB port and also have 1747-PIC
realolman
Mar 2009
here
584
I just was issued a new computer that doesn't have a serial port. There are several things that I need a serial port for, but I'm anticipating the most trouble with the 1747-PIC to communicate with allen Bradley PLC's.
Could someone suggest a usb to serial adapter , or just what should I do?
thanks
I have a USB port RFID Scanner I am using for badging users into certain access levels in an HMI. I know that I could create a 'login' button that...
613
I am trying to export the alarm history on a Panelview Plus 7 to a USB stick. I cannot get it to write to the USB stick. I have tried the...
6,138
Anyone know if a company makes a 24VDC power supply to USB (C) charger in place of a 120V outlet for programming? I have some panels with 480V or...
21
10,893
Is there an advantage to communicating to CompactLogix with the USB port versus Ethernet? I've always used Bootp to set the IP address on a new...
2,911
Hello, I have an AB PVP 6 with version 10 FactoryTalk ME firmware. I would like it to export the Audit Trail and Alarm History to a USB flash...
2,433
