1756-EN2T I/P Address
pravinshinde
Feb 2009
pune,India
57
Hi all,
I have 1756-EN2T version 4.3.
As per hardware switch setting and user manual we can set I/P address as 192.168.1.xyz.
I have tried to change I/P address(192.168.0.xyz) from module configuration face plate but it still gives me 192.168.1.xyz.
Is it possible to change I/P address to 192.168.0.xyz ?
No.
The switches can only be used to set the address to 192.168.1.xyz.
To set the address as you have mentioned, set the switches to a value above 254, but not 888. This allows you to change the IP address to any desired address using RSLinx. But you must have an established connection to that chassis using another communications path. You could also use a DHCP or BootP server.
OG
EDIT: If the switches are set from 001-254 they will override the "faceplate" setting.
So I have code to read the IP address of a 1756-EN2T with a MSG block - Get Single Attribute. Does anyone know where to find the MSG block...
1,158
Good day folks, We have an L71 processor (v30.02) in a rack with an EN2T connected to the plant network & another (v10.007) used for IO only -...
2,151
I've been trying to get this Ethernet module configured to send emails to our relay server but cannot get it to work. the EN2T is running...
1,772
Dear All, I have been using 5561 CPU with redundancy, Few days ago, I have seen the message Disqualified on RM module of secondary PLC. and i can...
782
I have a pair of 1756-L73 controllers on A4/A backplanes with PA72 power supplies, configured for redundant operation with RM2 and EN2T modules...
2,797
