1756 ENBT as I/O
Jan 2009
NH
505
I have a 1756-ENBT, some ControlLogix I/O, a rack, and power supply and want to use this hardware as ethernet remote I/O.
From this it says:
an adapter for 1756 I/O modules
so I think I can do this. In RSLogix5000, I can add the parts and all seems well, but my question is really how does this work under the hood? Can I use generic EIP scanners (other PLCs or software) to make Class 1 implicit connections and read this I/O? What assembly instances are there, and how are they derived? Is the mechanism producer/consumer, so limited to A-B CLX series only? I perused the eds file and it doesn't look good - I see no connections defined for the ENBT module so not sure how this is addressed. Any expert thoughts? Thanks!
please using the usb can i assign any ip address that i want ?
151
Hi, I want to exchange data between two L55 PLCs using ENBT PLC1 is the main PLC and consist of 1756- CNB, L55 CPU and ENBT. Five remote I/O racks...
1,034
Hey guys, I'm not super familiar with Cnet, so I'd like some insight from people with more ControlNet experience than I. We have a controllogix...
897
I am looking into an ethernet drive network system using a Logix5000 system Version 20 and noticed that on the general tab of the properties of...
1,138
I wanted to confirm with the Gurus that a 1756-ENBT can not create raw sockets. I'm using Rockwells Process Library's T_Sync to connect to an NTP...
2,003
