1756-ENBT IP address setup
Mark@GBW
May 2017
Bjerringbro
Hi everyone. I'm trying to give a new 1756-ENBT module a fixed IP address. I've plugged in to the module directly from my pc and ran BOOTP-DHCP server, the software has detected the MAC id of the module so I've selected it to give it an IP address. In the properties box I've given it the fixed IP address I want and it's moved to the relation list panel below. However when I go to click the disable BOOTP-DHCP button it always says "failed to perform operation".
I'm trying to build a DH+ to Ethernet bridge, so there isn't a CPU on the chassis to connect that way, there's only a 1756-DHRIO and 1765-ENBT.
Everything I've done is step-by-step from the Rockwell user manual for this device but I can't get it to disable BOOTP. Does anyone have any ideas?
I am looking into an ethernet drive network system using a Logix5000 system Version 20 and noticed that on the general tab of the properties of...
1,137
Hi everyone. I'm trying to give a new 1756-ENBT module a fixed IP address. I've plugged in to the module directly from my pc and ran BOOTP-DHCP...
4,290
Hi everybody, following the tip of Ken Roach, i'm opening a new thread to my problem. I have a redundant PLC system, each chassis have two...
7,943
Is there a way to read the configured IP address out of a 1756-ENBT programatically? I loked into a GSV and didn't find anything that applied...
6,750
Hello, Does anybody know if it's possible to change the MAC address of a 1756-ENBT?
5,643
