1756-enbt
plcengineer
Jan 2004
USA
176
Can I configure a controllogix processor out of the box with the ethernet port. I have always done it via serial port first, then used Enet.​
tks,​
Plcengineer​
The easiest way to configure ENBT IP address is to use processor serial port and RSLINX DF1 driver.
Just navigate to the backplane and to the ENBT in RSWHO
Did I understand your question correctly?
Well, that is the way that I have always done it. However, I heard the other day that you could do it before setting it up serially. So, I was wandering if anyone had done it. I don't know how.
Another way is to use a BOOTP server.
Some people don't like it, but it is relatively simple ones you used it few times.
The card does come with BootP enabled and the BootP utility comes with RsLinx.
One thing, what are you trying to accomplish by doing this. Do you not have a serial port? Not that I have an objection, just wondering your reason
Look at THIS manual beginning with page 3-3 and it will explain how to use the BootP to configure the Ethernet Address
Edit - Contr_Conn beat me to it, but still curious the reason
BootP for me.
My laptop doesn't have serial ports & I can't be bothered with a converter 90% of the time.
One other method you can use to configure the IP Address if you happen to have a Controllogix chassis with an ENBT already in it and a spare slot is to put the new ENBT in the chassis. You don't even have to plug the Ethernet connector in. You can then use the same DF1 method to configure the address in RsLinx only go through your old ENBT and drill down do the new ENBT
Just FYI:
New Logix Ethernet module 1756-EN2T will take care of these problems
It will have 2 new ways to assign IP address:
- Rotary switches with functionality similar to 1734-AENT
- Front USB port - just plug in USB cable and you will see module in RSlinx.
Just wait few months ;)
It probably goes without saying, but the biggest plus to using bootp to set the IP address for the ENBT module first is that you can download the firmware to the CLX processor much faster once you have the ENBT configured.
Thanks fo the BOOTP advice. We had been first connecting to a CompactLogix by serial and updating firmware that way. needless to say - many cups of coffee. Using BOOTP to set the IP then updating firmware has severly cut into my caffine intake.
please using the usb can i assign any ip address that i want ?
163
Hi, I want to exchange data between two L55 PLCs using ENBT PLC1 is the main PLC and consist of 1756- CNB, L55 CPU and ENBT. Five remote I/O racks...
1,042
Hey guys, I'm not super familiar with Cnet, so I'd like some insight from people with more ControlNet experience than I. We have a controllogix...
907
I am looking into an ethernet drive network system using a Logix5000 system Version 20 and noticed that on the general tab of the properties of...
1,142
I wanted to confirm with the Gurus that a 1756-ENBT can not create raw sockets. I'm using Rockwells Process Library's T_Sync to connect to an NTP...
2,006
