1756-HYD02 Problem
pct_jimmy
Dec 2006
Shady Spring, WV
61
Looking for anyone with experience on these modules. I had a strange problem this morning and I'm looking for an explanation and so far I can't find it.
Here's the story:
There was a feedback fault on two positioners on the same module, before I got in the plant manager had swapped the module with a spare and channel 1 came back. When I got in the maintenance personnel where checking over wiring in the field JB, they found nothing. I started over from scratch and checking everything and ultimately eliminating all field wiring. I could get feedback from both transducers if I connected them to another module but on only on one when connected to the proper module.
I then decided to swap positioner one and two on their module (swapped wiring on the plugs on the terminal blocks) and see what happens. When I done this both of them came alive and started working, opposite of course. I then said screw it and swapped channels in the program and downloaded it and so far so good.
I'm at a bit of a loss here and was wondering if anyone else has had any similar occurrences with these modules.
I should also note this mill is built on a Native American burial ground and someone thinks they saw a UFO but none of it can be substantiated.o_O
Thanks in advance.
We need help getting Physical Axis and Feedback faults on 1756-Hyd02 hooked to some temposonic ghs0140ud601-de2 sensors.
1,031
I tried to download the file from Rockwell but their EDS download has every rev EXCEPT 19. Rslinx won't recognize the device and I think it's...
2,442
I having an issue on my hydraulic card. my step feeder (channel 0) is getting cross voltage with my turning rolls (channel 1). i have checked...
1,227
HI: After three years my customer has changed his mind and he finally decided to use a motion control system instead of conventional analog...
37
10,269
I just wanted to get some advice from some of you who have upgraded from PLC5 to Contrologix and went to a 1756-HYD02 module from a 1771-QB...
3,561
