1756-IF8H intermittent error 16#0005 bad class?
bboytaktix
Jan 2015
Montreal Qc
26
Good morning all,
We are having a rather strange issue at one of our plants, wondering if anyone has dealt with this kind of problem before. We have a 1756-IF8H card on a remote backplane (ethernet connection to remote backplane) and this card seems to intermittently go into error. The error is 16#0005; bad class. I reset the module and it will work for a few hours or days but then the card will fault again. I know that bad class could be bad assembly instance numbers for a general card, but since this is a 1756-IF8H HART Analog input module, there are no instance numbers to program. I checked the card's revision vs. the HART-returned revision number and all seems to match up.
edit: I searched the forum for the error and card type and did not find any relevant topics. I may be 'new' to programming (only about 5 years) but not at all new to forums!!!
thank you for your insight!
I reset the card and it worked for less than a day then went back into error, this time error code 16#0204 connection request error. I am contacting Rockwell techsupport to see what they think, I am leaning towards bad backplane or something electrical. While I am waiting I will have our local engineer switch the card to another slot in case the backplane slot is no good. Will let you know what I find!
Hey guys,
Still getting this error, I will be contacting Rockwell directly to try and solve this with them; let me know if you have any ideas.
Good afternoon, I came with a question, currently i have a remote chassis with an series of modules I/O, digital and analog,the analog module...
1,186
Hello All, I'm programming a 1756-IF8H to configure a Rosemount 8712E magnetic flow meter. I'm able to read the registers but the AB literature...
1,382
anyone have any sample code on how to programm the 17560if8h module
1,413
Anyone have experience using this module they can share? I like the idea of retrieving more data from an input channel than the one being read by...
2,409
Does anybody know what the differences are between 1756-IF8H vs 1756SC-IF8H?
3,679
