1756-L61 Firmware Upgrade
bluenoser337
Apr 2003
Nova Scotia
391
Hi: Trying to upgrade firmware in an L61 from 15 to 20 but L61 is not in the catalog in ControlFlash (v12). Downloaded the firmware file from Rockwell but it's still not in the catalog. I suspect the problem is where I am putting the downloaded file. Tried a bunch of locations but no luck. :cry:
Thanks labeledas!! It was an exe that produced a dmk. I tried downloading and installing v14 (the complete package) and my L61 download was then on the list. Thanks again !!!!!!!!!!!!!! 🍺
Some firmware downloads give you an .exe, some downloads give you a .dmk. I've never been able to work out a pattern.
If you get a .dmk, you need to run the DMK Extraction Tool, found in Start>All Programs>FLASH Programming Tools (this is for Windows 7 - I just click start and type "DMK", it always comes up from there).
That will register the firmware with ControlFlash, and then your target hardware should be available.
hello i had a 1756-l61 with firmware ver 13.24. a solid red made the processor not functioning. i ordered a processor that came with firmware ver...
3,820
Hi, we are using 1756-L61 PLC redundant system in one location . due to some minor faults , we upgrade the firmware from 19.52 to 20.58. after...
1,334
Hi, New to control logix, But we have a L61 controller on our Generator E-House control that is only FW 17.2 We need to make changes to...
4,627
I have a SD card with a program I would like to retrieve but it is in firmware 13.40 and all I can seem to find on Rockwell's website is 13.44...
1,570
Is it true if I update the firmware of my rev 13 1756-L61 Controller to rev 15, I cannot flash back to rev 13 after I'm finished testing at rev 15?
4,584
