1756-L71 USB Connection
swva
Aug 2013
WV
I am trying to connect directly to the 1756-L71 processor I have using a USB cable. The manual says if you have RSLINX 2.57 installed (I do) that the USB driver will automatically configure when you plug into the PLC with the USB cable. For some reason it doesn't and then I get a "driver not found" message from Windows 7. Is there any way to configure a driver to connect directly to the PLC using a USB cable if it does not automatically install the driver like it says? Thanks in advance.
Ok so I followed the link and sort of lost my will to live reading it. It didn't really apply to the question asked here. Or did I miss something?
So, to the OP.....Do a Windows Update. In my experience, it will grab the driver for you.
OG
Hello, I have a pair of redundant 1756-L71 controllers rev 24. These controllers currently have produced and consumed tag interfaces to 3 other...
176
Hi All, We have a number of old discontinued 1756-L1 PLC systems that we are trying to support but recognize that we need to start preparing to...
985
Two days ago I used Control Flash Plus to upgrade the firmware on a 1756-L71 controller from v20.13 to V35.12. The upgrade aborted soon after it...
1,140
I have followed several videos and tutorials that suggest when using the MSG function to enter 2,xxx.xxx.xxx in the Path box in order to connect...
1,395
I have read through this pub: Rockwell Automation Publication 1756-RM010M-EN-P - November 2022 I have questions. The procedure in the pub above...
1,003
