1756-L72 firmware upgrade
Status
Not open for further replies.
sifis said:
...Thank you for the advice.
Good advice is usually based on good information. Usually.
I am not worried in the slightest, my friend, and good luck with your endeavours.
G.
Be advised when you flash the firmware, it will delete the program that is in the processor. Be sure you have an up to date backup of the program BEFORE you try to update the firmware. You will need Studio5000 with a version number that matches the firmware revision to put the program back in the processor after flashing it.
Status
I downloaded Controlflash from the AB site. I cannot get it to run. Thank you.
3,410
Hi all. I am working with 1756-L72 processor in a redundant pair chassis. The publication ControlLogix Enhanced Redundancy System, Revision...
7,962
Hello, We have a customer with a 1756-L72 ControlLogix PLC. They have recently got a T01:C62 Fault Code. I am trying to figure out how to...
1,057
I would like a sanity check on an application i am working on. I have a proximity switch counting pulses with a Mark/space ratio of 1:1 on a...
1,882
Hey Members, I hope all of you are doing well , I am using a 1756-l72 redundancy system, communicating RIO on DLR network. When both my PLC are...
2,435
