1756 L81E GSV WallClockTime discrepancy
bigLee
Jun 2018
Florida
77
Hello,
I am doing a PLC5-Contrologix plant migration. So far with the same exact GSV WallClockTime to DateTime array half of my controllers report the correct hour and half do not. All settings are the same, Daylight savings time, UTC eastern time zone, etc. Time was set from desktop option.
The common issue is the controllers with incorrect hours are all 4 hours ahead. So right now EST, 11:40 am is showing as 15:40 in DateTime[3].
Any ideas on a resolution? I've already, reflashed, etc.
Thanks!
Ben
Hello,
Thanks!
Ben
Is the timezone on the desktop correct? I had some issues on my side too. I needed to make sure the PC timezone was set properly.
If not, I would do this:
1)Set Date, time and Zone from Workstation
2) Change time zone manually to the correct zone.
These steps should fix your time.
I am using Allen Bradley PLC 1756-L81E and EIP module 1756-EN2TR for Ethernet/IP communication. My communication works fine but in Get-Attribute...
207
Hi there, I have a small set-up of redundancy system with 1756-L81E 1756-EN2TR 1756-RM2 but I need 3 ethernet ports for my system. I have...
1,226
:banghead: Remote I/O The occasional times i have had to deal with blue hose/PLC5 I/O addressing it always wrecks my head. Now i am working on...
3,287
I have now had two 1756-L81E processors that are unable to go online with. The first one bricked and needed to be replaced. I have a second...
2,352
I have been doing some research on data highway and data highway plus, and have contacted Allen Bradley for information regarding communication...
2,852
