1762-IF2OF2 Analog Input reading unstable
w_thanong
Jan 2013
Bangkok
1762-IF2OF2 Analog Input Problem
I use Micrologix1100 and explantion 1762-IF4 and 1762-IF2OF2 I config and wiring and test but use 2 wire for 1762IF2OF2 ANALOG input Reading unstable 2 points i Follow Manual but it still reading unstable
Define unstable.
Noise? Are you using shielded wiring?
If that does not help then you may want to consider a filter. See text.
But try to find out why first.
Hey all, Been working on a little project using a Micrologic 1100, Just added this 2-in/2-out analog module (1762-If3Of2)to my project, and a...
2,192
just re-uped membership so thanks for help previous and future. Bear with me on typing or responses back, pinky finger is broken and typing has...
8,330
The MicroLogix manual states the Output Data File is from 0 to 32,760. My fluid Flow application calls for a control valve to open progressively...
3,679
Ladies & Gentlemen: I have the following configuration: Micrologix 1200 Rev C 1762-LW40BWA processor with one 1762-IF2OF2 analog i/o card I...
22
32,719
I have a Moog hydraulic servo valve that operates a cylinder that moves up and down. I have the 1762-if2of2 hooked up to it and sending the 4-20ma...
2,624
