Analog Output Data File: 1762-IF2OF2
bamab
Jul 2007
Boston
The MicroLogix manual states the Output Data File is from 0 to 32,760.
My fluid Flow application calls for a control valve to open progressively from 0 to 100%, once it reaches a minimum GPM.
For every 50 GPM it will move a value to the output increasingly.
500 - 550 GPM Open 5%,
550 - 600 GPM Open 10%
. . . etc.
Is the 0 Output Data File right? For my input I used a 4-20mA calibrator and scaled the value.
Is every 1638 the value to use? ex. 1638*20=32,760
See below for data format guidelines ( it says IF4/OF4 but its the same for your module, just disreguard the -10 volt data)
Hello! Hope you are great. I need to make a change in a PLC with ladder logic. I will mount a analog valve and I need to control it in ramp up...
319
I have a 170AAO92100 card that I am interested in using as a 10 volt output. Is there setup that I have to do in order to change output or simply...
86
Hi We're having issues with an FX1N-1DA-BD Analog output module. We're using an metallic contamination sensor MCS 1000 to detect particles. This...
109
248
I have a program that I am gradually piecing together (my first program). There are 4 cascading timers that turn Y001 and Y001 + Y002 on and off...
544
