1769-IF16C Micrologic
phan8314
Jan 2013
Ga
I got 14 Yokogawa Admag AXF Flowmeter going to this card on a Micrologix 1500. Just realize that a 4 wire instrument will not work with the card Can someone recommend a Signal Conditioner/Isolator from www.ab.com? (Will a 931H-A1A1N-IP work from them?)
And why is that? Are you sure?
If the transmitters cannot share the same common would be the only thing I can think of which would prevent you from using non-isolated inputs.
My PLC is currently running the program and the process is still live. One of my 1769-if16C cards values are all frozen but the card is not...
126
Hello, I was wondering if anyone has any leads on a 1769-IF16C Digital Input card? I need one for testing systems, doesn't need to be BNIB, just...
1,716
Can I use 4-wire with the 1769-IF16C? The 1769-IF8 has a COM for each input and the IF16C only has 2 Com.
1,067
Hey Guys, I have a few questions regarding a 16 channel analog input card for compact logix. 1769-IF16C. In the Module-Defined tags that get...
2,137
Hi all, I'm using a Compactlogix PLC with 1769-L32E processor, 1769-IF16C, 1769-OF8C input and output modules.I'm using RSLOGIX5000 to develop the...
5,914
