1769-if16c
redviper
May 2011
Calgary, AB
19
Hey Guys,
I have a few questions regarding a 16 channel analog input card for compact logix. 1769-IF16C.
In the Module-Defined tags that get generated when it is added:
There is DINT "Local:10:I.Fault" that is a fault code for the module. Does this word contain channel faults? Cannot find any docs on this.
There are Status bits as well "Local:10:I.Ch00Status" curious what this "status" reflects? I cannot find any docs on it.
At the end of the day, I am looking for individual channel fault status.
Thanks,
K
The DINT apparantly only returns entire module faults, not any specific channel faults.
I was also told by tech support it is not accurate and was not fully tested by engineering, so I cannot trust that anyways. Staus bits are not reliable either.
Solution: Take the raw value and compare that against my setpoint for a fault. Keepin it old school i guess.
This kind of makes me mad.
In my mind it is totally unacceptable for ANY company to send anything out to be used that is not fully tested.
And then for them to admit it!!!!!
Mark
My PLC is currently running the program and the process is still live. One of my 1769-if16C cards values are all frozen but the card is not...
124
Hello, I was wondering if anyone has any leads on a 1769-IF16C Digital Input card? I need one for testing systems, doesn't need to be BNIB, just...
1,714
Can I use 4-wire with the 1769-IF16C? The 1769-IF8 has a COM for each input and the IF16C only has 2 Com.
1,064
I got 14 Yokogawa Admag AXF Flowmeter going to this card on a Micrologix 1500. Just realize that a 4 wire instrument will not work with the card...
1,772
Hi all, I'm using a Compactlogix PLC with 1769-L32E processor, 1769-IF16C, 1769-OF8C input and output modules.I'm using RSLOGIX5000 to develop the...
5,912
