1769-L30ER load firmware and program from SD card
bhedding024
Jan 2004
Great Falls, MT
29
I'm in the process of installing a new 1769-L30ER controller as a retrofit to a 1794-L34. I'm trying to find out if I can load the firmware and program into a brand new controller without having to connect a computer to the controller. Any time I've ever set up NV ram before, I've done it while connected to the PLC. I've been reading about setting up the controller to read from the SD card in the event of corrupted memory, or on every power-up but not sure exactly how that's going to work. I'm trying to accomplish all of this remotely without having to walk them through updating their software to V32.04 and how to use control flash, etc. I'd appreciate any feedback or advice. Thank you!
Unless you're prepared to be their remote support person for the long haul, I would try to walk them through adding v32 to their installed software. It shouldn't be that difficult.
Are you able to prototype the PLC and have it at least initially programmed ahead of time?
Good morning everyone. I have a situation that is really stumping me. I have three separate but identical machines, all running 1769-L30ER PLCs...
3,522
Good afternoon. I have an issue that I have never encountered before and am uncertain of where to start. I have three machines, all with...
944
Hey everyone, I am trying to message to a IndraControl L45 controller that I do not have access too. I have been given given a list of addresses...
1,335
Hello Friends I need to replace a Micrologix 1400 L32BWA with 1 1762-OB16. I had thought in a 1769-L30ER, 1 1769-IQ32 and 2 1769-OW16. But...
2,408
Hi All, apologies I don't have access to a remote IO module to test this out. I have a number of remote IO blocks, each with approx 8 IO cards...
2,153
