1769-SM2 Modbus RTU - MSG Command Freezing
calvin127
Dec 2007
Philadelphia
Hello Everyone. I am using a 1769-SM2 Module to communicate Modbus RTU to a third party device, using the first serial port. I am using MSG commands to handle the communication through the SM2 module. I have a MSG dedicated to one register (FC6 write) and this particular MSG appears to "freeze" at a random interval. Reading all the documentation on MSG blocks, the only time a MSG will write is when conditions before the MSG on the rung are true (if any).The EN stays true, even though the "preconditions" on the rung to run the MSG are false. My guess is that this particular register point is getting stuck, hence causing the MSG to continue to try to write down until it gets a response. Has anyone else had this experience? Also is there a way to kill the MSG command, outside of putting conditions on the front end (i.e. is there a bit in the MSG word I can get which will reset the MSG block)? Thanks in advance.
Hello everyone. I'm trying to communicate a Controllogix L36ERM with a 1769-SM2 Modbus module to a Schneider-electric Altivar 312 Modbus motor...
2,486
Hi All. I am trying to relocate a simple MODBUS system from a MicroLogix 1400 (on channel 0 set as a Modbus RTU Master) to an CompactLogix SM2...
1,817
I am using a 1769-L35e with a 1769-SM2 (latest firmware) to communicate with a MicroMotion transmitter (9739MDV) that automatically detects serial...
3,567
Hello! I have a one problem with 1769-SM2 module... I use PLC 1768-L43 and modbus module 1769-SM2. There are 4 devices in modbus net: CH1 - two...
27
9,298
Dear all! I am trying to Communicate with one temperature controller(Honeywell DC1040) using Miglogix1500&1769sm2 module via Modbus...
5,717
