1771 PLC parts
zqew05
Jun 2003
Alabama
110
HELP !!! I/m new to this, I'm trying to buy parts for a trainer I'm attempting to build. I have a 1785-L40C Processor Module. Bellow is a list of items I am trying to buy from someone but I'm trying to make sure they are compatible with the processor I already bought. I'm a newbie. Below is the list of items being offered for one price for all:
1 EACH 16 SLOT I/O CHASSIS, 1771-A4B
1 EACH PLC 2/30 PROGRAMMABLE CONTROLLER, 1772-LP3
1 EACH 120 VOLT AC POWER SUPPLY MODULE, 1771-P4 OR 1771-P4S
1771-OA, 120 VOLT AC OUTPUT MODULE
1771-IA, 120 VOLT AC INPUT MODULE
1771-IBD, 10 TO 30 VOLT DC INPUT MODULE
1771-OB, 12 TO 24 VOLT DC OUTPUT MODULE
1771-OGD, TTL OUTPUIT MODULE
1771-IXC THERMOCOUPLE INPUT MODULE
1771-IFC, ANALOG INPUT (12 BIT) MODULE
1771-OFC, ANALOG OUTPUT (12 BIT) MODULE
THANKS
Hey there, I hope those starter notes were a help tp you.....looks like this system has everything you need and more to get going. You have a great processor for a starter and a good variety of cards to get to know Hardware with the code 1771 will be compatable with your PLC5 family, you will not need the other processor though (plc2/30 1772) but if it comes withe package, what the hey. Look at allenbrabley.com for more information on specs and settings for the DIP switches on the chassis and other hardware to get up and running. Let me know when you are going to attemp the set up and I'll send you some more of my school notes if you like.
Take care
JEFF ALFORD
Thanks Jeff. Will sure do. I've also talked to Mr. Ron on any last minute advice. You guys will be great resources for me in trying to learn a new trade
ZQEW05
Brother
i am sorry Brother because I am still fresh and start to learn PLC. Regarding drawing for hardwiring, i had a lot of panels done here in our plant. So I think that the only thing I can extend my help on you is to provide or prepare a drawing for you in Auto Cad. Just inform me if you need too, and I'll try my best to do it.
Good Luck to your project.
about that list ...
Noel,
you already have: 1785-L40C (PLC-5/40) Processor Module ... EXCELLENT! ... more horsepower than you’ll ever need for student training purposes ... also, this is an “enhanced” type processor so you’ll be able to program it with a simple (cheap) RS-232 connection - rather than being forced to use the expensive DH+ (Data Highway Plus) alternative required for the older “classic” type processors (example: PLC-5/15) ...
1 EACH 16 SLOT I/O CHASSIS, 1771-A4B ... excellent - again more room than you’ll ever need for training purposes ...
1 EACH PLC 2/30 PROGRAMMABLE CONTROLLER, 1772-LP3 ... as Jeff said, this is an older technology ... I wouldn’t recommend going out and looking for one but as long as it’s part of the package, you could always use it for a high-tech paperweight ... plus there are quite a few companies still using these old beasts - someday you just might be glad you have one around ...
1 EACH 120 VOLT AC POWER SUPPLY MODULE, 1771-P4 OR 1771-P4S ... excellent ... but you might have to buy a 120 volt connector for the power connection ... when systems are butchered, a lot of guys just rip out the plug and leave it hanging on the end of the wire ...
1771-OA, 120 VOLT AC OUTPUT MODULE ... good but only 8 outputs ... 1771-OAD would be better with 16 outputs ... still - if the price is right - go for it ...
1771-IA, 120 VOLT AC INPUT MODULE ... good but only 8 inputs ... 1771-IAD would be better with 16 inputs ... still - if the price is right - go for it ...
1771-IBD, 10 TO 30 VOLT DC INPUT MODULE - excellent ... this will give you 16 points of 24VDC input capabilities ... be aware that this is a SINKING type module - not a SOURCING type ... that means that your inputs must provide +24VDC to turn on the inputs ... so any 24VDC sensors that you eventually buy should be PNP or sourcing-type sensors ...
1771-OB, 12 TO 24 VOLT DC OUTPUT MODULE ... good but only 8 outputs ... 1771-OBD would be better with 16 outputs ... still - if the price is right - go for it ...
1771-OGD, TTL OUTPUT MODULE ... good ... but you’ll probably find very little use for this one ... TTL stands for “transistor to transistor logic” which basically means low voltage DC signals (something in the 0.5 to 5.5 volts range) ... even so, you can still control the 16 LED’s on the front of the module as part of your training experiments ... there’s no such thing as “too many” flashing lights on a student programming project ...
1771-IXC THERMOCOUPLE INPUT MODULE ... no such animal that I know of ... so you probably meant to say 1771-IXE ... if so, then EXCELLENT! ... very handy for temperature experiments ... just don’t rush out and buy expensive thermocouples to go with it - just get your hands on some of the thermocouple hook-up wire ... strip the insulation from about a half inch at the end and twist the two wires tightly together ... that will give you a dirt-cheap thermocouple that will work perfectly for student exercises ...
1771-IFC, ANALOG INPUT (12 BIT) MODULE ... no such animal that I know of ... so you probably meant to say 1771-IFE ... if so, then EXCELLENT! ... very handy for analog experiments ... we can talk about how to build bargain basement inputs as we proceed ...
1771-OFC, ANALOG OUTPUT (12 BIT) MODULE ... no such animal that I know of ... so you probably meant to say 1771-OFE ... if so, then EXCELLENT! ... very handy for analog experiments ... there are three types of these so be more specific from now on ... 1771-OFE1 gives analog voltage outputs ... 1771-OFE2 gives analog milliamp outputs (4 to 20mA) ... 1771-OFE3 gives analog milliamp outputs (0 to 50mA) ...
the last three (all analog) modules are excellent because they’ll give you the ability to learn about Block Transfer Reads and Block Transfer Writes ... a PLC-5 subject that most entry-level job applicants have little or no knowledge about ...
final thoughts ... do all of these modules still have their swingarms (terminal strips) with them? ... you’ll need these to make the electrical connections ... many bargain basement systems are butchered out of old machinery ... unfortunately the quickest way to rip out the equipment is to simply snap off the swingarms and leave them dangling on the ends of the cabinet wires ... you CAN buy the swingarms separately but they’re not cheap (about $40 each list price) and it’s a hassle to have to order them when all you want to do is to start playing with your new toys ...
all in all - it sounds like a lot of neat stuff - BUT if you didn’t already have that processor, I’d probably tell you to look a little bit further ... anyway you can send me the price in a private message if you like and I’ll let you know whether it sounds reasonable ... those last three analog modules alone might be worth what the seller is asking ...each one of those has a list price of around $1500 ... and there’s a LOT of student training horsepower right there ... far beyond flashing lights and pushbutton switches ...
Ron,
Thanks for the input. Now that you mentioned how expensive the 5/40 processor is, I'm a little worried where the seller got this thing I bought for cheap. I did not ask for a receipt (stupid me). This whole assembly I'm fixing to buy will be on Ebay, I feel safer buying it on Ebay because now I have proof where I got the items. I don't want my boss to think I got it from work. I'll print a hard copy of the Ebay ad and ask for a receipt from the Ebay seller, just to cover my a**. I'll call you on the phone for some minor questions, just woke up in mid-afternoon after 8 hours in bed. Pain killers knocked me out, back somehow started hurtin' more
ZQEW05
Thanks Ron,
The seller has several other cards and is willing to swap several cards. What would you recommend I take out and what would be a good replacement?
ZQEW05
what's he got?
there are over 200 types of modules that will plug into a 1771 chassis - so what's he got available? - plus i pretty well told you what would "be better" (OAD, IAD, etc.) in the earlier list -
a relay-type output card would be nice - then you could control just about any voltage level ouputs - and did you ask him about the swingarms? -
Ron,
I got outbidded on the Ebay auction but it made me realize a 16-slot rack would be too unwieldy in my spare bedroom. Howzabout a 4-slot chassis?
ZQEW05
OK Ron, I'll start looking for an 8-slot. ZQEW05
CUNFUCIUS SAY: A JOURNEY OF A THOUSAND MILES STARTS WITH THE FIRST STEP....OR WAS IT GEORGE CARLIN ???
A question was sent via PM this morning from a new member (Vince9521, from up in Timmins, Ontario) that I'm promoting to the main forum:
1,079
Hey everyone, Trying to bench test the I/O on a program that I converted from a PLC-5 processor to a ControlLogix processor but still using the...
21
6,532
These two RTD's are wired to channels 1 and 2 on a 1771-IR in a remote rack, communicating to a PLC-5/40 through an ASB. I believe that the RTD's...
1,970
Hello, I am in the process of migrating a PLC-5 system over to ControlLogix and could not find any equivalent modules to convert the 1771-ALX...
1,494
Hello, I am trying to create a network status map at a plant. I'm assuming the comm status bit of dnet nodes is in the BTR/BTW instruction that...
983
