1771-vhsc or 1771-ij
Need more info
It seems a simple question - using either an encoder or switches. We just want to measure wind atmospheric speed 0 to whatever the wind speed is - not a wind tunnel so usually under 20 but as high as 80
So we want to know which is easier to get the results,the 1771-high speed counter has automatic frequency conversion so we were leaning that direction instead of the IJ but we don't have experience with either module.
I can't vouch for the 1771 platform as I've only used these modules on the 1734 Point I/O platform. But on that platform, the VHSC is basically the same as the IJ/IK but with configurable high speed outputs on it as well.
So, if you were using the 1734 platform and looking only to measure, I'd be pointing you at the IJ/IK (difference between IJ and IK is the voltage) since you have no need for outputs.
Perhaps check to see if the same holds true for the 1771 platform?
The big difference for this application with the high speed counter is I would not have to compute the frequency since the module is configurable to do it automatically otherwise not much difference.
I am not sure how I would calibrate/program the VHSC to get the frequency to wind speed yet so....
I like the suggestion to use an analog input module an buy a anemometer. Might be the best choice.
From the manual: " Use the period/rate mode to determine the frequency of input pulses by counting the number of internal 4MHz clock pulses over...
1,863
Converting a PLC-5 to ControlLogix, still using some old PLC-5 hardware as remote I/O. My issue is I have a 1771-VHSC card in a remote rack away...
2,456
Have read most of these postings on this module I got a new one for ya One encoder with channel A wired to A1 and A2 IE Counter 0 and Counter 1...
2,471
I have an application coming up that will have 2 oil shear brakes on opposite sides of a differential. I need to be able to control a speed...
1,729
Hello all, I am adding a 1771 VHSC card to an existing system in order to more precisely control part positioning. The problem I am having right...
2,802
