PLC 5/20 & 1771 VHSC- BTR not working
blue52
Jul 2010
Ohio
Hello all,
I am adding a 1771 VHSC card to an existing system in order to more precisely control part positioning. The problem I am having right now, is that I can not get the BTR to read the data from the VHSC.
I have the BTR and BTW setup as recommended in the manual with the NC enable bits in series with the commands. None of the enable bits ever seem to turn on. The VHSC is in slot 1 (power supply in slot 0 and the VHSC in the slot immediately to the right of that) and I believe that I have the R/G/S setup correctly, 0/1/0.
I am able to force the outputs on and off (the lights on the front of the card actually turn on and off) using the setup screen on the Block transfer instruction, but the BTW will only execute once. The lights for the encoder channels A and B flash when I jog the motor, but no count is ever recorded in the setup screen or in the register the BTR should be writing to.
I am not too familiar with block transfers so any help is greatly appreciated.
It may help someone help you if you could post your .RSP file ( zip it first)
Note: I have not used that card but I'm sure someone has.
Thanks for the reply.
After posting, I sat back and looked at the whole program. I noticed none of the timers were updating either. After looking around for a few seconds I noticed someone AFI'ed the JSR instruction in the main file. So yeah now I feel like an idiot, but at least I can move forward with this thing.
Thanks again
A question was sent via PM this morning from a new member (Vince9521, from up in Timmins, Ontario) that I'm promoting to the main forum:
1,075
Hey everyone, Trying to bench test the I/O on a program that I converted from a PLC-5 processor to a ControlLogix processor but still using the...
21
6,514
These two RTD's are wired to channels 1 and 2 on a 1771-IR in a remote rack, communicating to a PLC-5/40 through an ASB. I believe that the RTD's...
1,964
Hello, I am in the process of migrating a PLC-5 system over to ControlLogix and could not find any equivalent modules to convert the 1771-ALX...
1,489
Hello, I am trying to create a network status map at a plant. I'm assuming the comm status bit of dnet nodes is in the BTR/BTW instruction that...
979
