1783-etap
House92
Dec 2014
St.Louis
35
Hello.
I am setting up my second Device level Ring. Presently I do not have a physical ring. When I plug inmy last remaining ENET cable all of my drives fault. I assumed it was because I did not set up the ETAP as a superivisor and was seeing duplicate IPs. I verified with other DLRs in use and all settings look the same. I alos noticed in the ETAP properties it shows last active node on port one as the IP address of the drive that the enet cable is unplugged. The last seen IP address on port 2 is the actual ETAP switch. This would indicate 2 breaks but I am still communicating out of port 2 to 4 drives up to where the enet cable is unplugged. Any ideas?
Thus far i checked for duplicate IPs and found none. I deleted the ETAP from the IO Tree and re-added. I configured a different switch in the shop. Nothing has worked. Any ideas would be appreciated. Thanks JOHN
The Last Active Node fields display the last fault information even though it has been corrected. To clear the last fault information from these fields, click "Verify Fault Location" button (in ETAP properties - Network tab).​
When the dialog box appears that indicates the supervisor is no​
longer in fault mode and the fields are cleared, click OK.
2) I am sure that u r not using device port of ETAP in ring.
Greetings, I have a network topology that is using 5 Stratix 5400 switches that has 2 separate DLR networks configured. The DLR ports are set to...
5,064
Hello all. I have a CLX redundant chassis set up using a pair of RM and CN2R modules, and a pair of 1756-L62 controllers (basic layout stuff for...
4,160
I have a system that is using a 1756-L61 which is communicating via ethernet to a remote rack using a 1756-ENBT. The client wanted a redundant...
7,884
Is it possible to gather OPC data through a 1783-NATR? Searching around, it sounds like OPC data might be blocked by any NAT... Is there any work...
248
Good morning all, I have a project that has quite a few NATRs to configure. I would like to modify the generated backup config file because I...
434
