1784-PKTX DH +connection
meghnesh
Jan 2011
Gujarat
82
Hi All,
A quick question.
I have one Computer with 1784 PKTX Card for interfacing with DH+ Network.
One PLC nearby control room has got:-
1. 2 Nos. of DH+ Cable coming from the field and Terminating at DH+ connector at PLC
2. One DH+ cable going to the PKTX card from the same PLC's same DH+ Connector.
So the PLC connector has got 3 DH+ cable.
CAN I HAVE ONE MORE DH+ CABLE FROM THE SAME PLC's SAME DH+ CONNECTOR GOING TO A DH+ to ETHERNET GATEWAY ?
DH+ is a daisy-chain type network.
There can only be 2 cables going into 1 connector, or 1 cable + termination resistor into 1 connector.
T's or stubs are not allowed.
(There exists a special box that can be used to make a T joint, but even with the special box it is not recommended.)
Thanks for your reply.
But I have seen at site the DH+ connector had total 3 cables. How did that worked i am wondering?
And can you suggest me a device like a TAP or something of Rockwell make ?
It is very common for installers to violate the wiring guidelines for DH+.
A short "dropline" like the one you describe frequently works well on DH+. DH+ technology is very robust and tolerant of poor signal quality.
But it's still technically against the installation guidelines.
The old Allen-Bradley "tap" was the 1770-SC Station Connector. These have not been built for many years, and are really just a box with terminals and a small capacitor inside.
If you think the "dropline" is the problem, you can just eliminate the dropline by running the DH+ cable out to the 1784-PKTX, then back to the PLC.
Hey everyone, Ran into an issue on a customer's system a couple times recently and wanted to check if anyone might have any clue what's going on...
1,402
I have and old computer running controlview300 in dos. I’m try to update to rsview32. But the question I have now is getting communication...
2,792
Has anyone tried using a 1784-PKTX in a PCIe slot, using a PCIe to PCI adapter? :scratch:
1,375
Hi, Previously we used SS5136SD DH+ cards for communicating with Allen Bradley SLC 5/04 PLC utilizing Wonderware free SST5136 DDE server. This...
2,851
IT is replacing and upgrading one of our xp computers to windows 7. Does anyone know if there are any issues doing this?
3,975
