RsLinx Classic and Intouch 10.6 with AB 1784-PKTX card
kemppioy
Oct 2005
Dallas
72
Previously we used SS5136SD DH+ cards for communicating with Allen Bradley SLC 5/04 PLC utilizing Wonderware free SST5136 DDE server. This was back in the days before even XP arrived. Now with Windows 7 32 bit operating system I needed to use AB 1784-PKTX DH+ card and RsLinx Classic with Intouch 10.6 because I couldn't get the latest SST-DHP-PCI card quick enough. The PLC and Intouch communications are working ok but sometimes the communications stops and I need to reboot the PC. I created an error log to track the RsLinx comm errors. Do I also need to integrate the RsLinx somehow into Wonderware system management console or should it work without any integration?
The RsLinx error report shows the following. This is just an excerpt.
RSLinx Classic v3.71.03.00 started Wednesday, September 09, 2015 00:56:03 AM
Log written Wednesday, September 09, 2015 01:11:00 AM
ABPLC : N7:9 : 09/09/15 - 01:02:50 : 05h
Items: N7:9
Type: WRITE
Mfg: Allen-Bradley
PlcType: SLC-503+
Desc: Local Error: TimeOut
The application layer time out while waiting for a response.
Number of occurrences: 4,489
Last Error occurred: 09/09/15 - 01:11:00
AB_KT-1\001 : F51:40 : 09/09/15 - 01:02:50 : 05h
Items: F51:40
Type: READ
Mfg: Allen-Bradley
PlcType: SLC-503+
Number of occurrences: 52
Last Error occurred: 09/09/15 - 01:10:56
AB_KT-1\001 : F41:40 : 09/09/15 - 01:02:50 : 05h
Items: F41:40
Type: READ
Mfg: Allen-Bradley
PlcType: SLC-503+
Last Error occurred: 09/09/15 - 01:10:57
AB_KT-1\001 : C44:0.PRE : 09/09/15 - 01:02:50 : 05h
Items: C44:0.PRE, C44:0.ACC, C44:1.PRE, C44:1.ACC, C44:2.PRE, C44:2.ACC, C44:3.PRE, C44:3.ACC, C44:4.PRE, C44:4.ACC, C44:5.PRE, C44:5.ACC, C44:6.PRE, C44:7.ACC, C44:7.PRE, C44:8.ACC, C44:8.PRE
Type: READ
Mfg: Allen-Bradley
PlcType: SLC-503+
AB_KT-1\001 : F13:0 : 09/09/15 - 01:02:50 : 05h
Items: F13:0, F13:2
Type: READ
Mfg: Allen-Bradley
PlcType: SLC-503+
Thanks for any advice!
Br,
PK
Hello Everybody, I use RsLinx connection to Intouch. Occasionally,Intouch and RsLinx disconnected,and wait for 30 min or more, Redundancy module...
2,825
Hi, I am working on a project, where I face a issue with respected to Network Dropout. The PLC is connected to a 16 port unmanaged switch, where...
191
Hey All, I am sorry to ask this, but i still gotta do it. What happens if I close RS linx? Will it cause network interruption and PLCs will lose...
158
Does anyone know if there is a way to import RSLinx Classic data into FT Linx? We have a quite extensive configuration set up, and it would be...
2,590
Hello, I entered my controller IP address as 192.168.1.100 (Local) for 1769-L33ER. It worked fine until couple month and found the controller kept...
1,135
