1794-ID2 Flex Encoder module with SLC 5/05
May 2009
St. Louis, MO
Hi, I'm new to the forum. My company works exclusively with Allen-Bradley products. I need help with programming roll-over code for this module. Again, I'm using a 1794-ID2 Flex Incremental Encoder module with a SLC 5/05 CPU. The encoder module is on an RIO rack. I have already programmed the configuration for the module with BTW/BTRs and I'm seeing an input from it. I understand the basic concept of the math involved in getting the counts to roll over properly. Let me explain: I made the preset of Ch0 32000. So when the counter reaches 32000, the counter automatically resets. I made some logic that did work at first using a GEQ (Greater Than or = to) instruction to keep track of how many times I rollover. I take this value and multiply by 32000 and ADD this result to what the counter is currently at to get my total counts... I hope this makes sense. But, the problem is that whenever the pulses come in fast, the PLC doesn't scan fast enough for my GEQ to work and keep track of how many times I've rolled-over.
I discovered that the encoder has a "PresetReached" bit that triggers when, you guessed it... when the preset is reached. So... I used this PresetReached bit in place of the GEQ and this took care of the scan issue. But the PresetReached bit latches ON and can only be reset by the "PresetReset" bit which is part of the configuraton block. So I called Rockwell support to see if they could help me out. They said to execute another BTW when the preset is reached to activate the PresetReset bit. And also to use the same control block as the first BTW. It seems rediculous to have to go through this much trouble and execute 2 BTWs per channel to get the module to rollover. I haven't had a chance to test out what Rockwell told me yet.
Does anyone have any experience or code using a 1794-ID2 Flex Encoder module in conjuction with an SLC 5/05? If so, please help.
Thanks in advance.
Good Morning , I am going to be re-working 2 portable machines. I am going to have one main panel with a CompactLogix and 3 PowerFlex...
1,491
I am using an oval gear meter with a pulse rate of 2050p's /L. I am trying to figure out how to program a rate counter to track flow rate at...
2,640
Hi Everyone, I need help with setting up 1794-ID2 Card with push-pull type encoder with A+ (Up counting) and B+ (Down Counting). The 1794-ID2 is...
1,557
I see no threads about the 1794 ID2 incremental encoder module. I have used Flex logix before but have not done Block transfers to any of the...
3,085
Just a few quick question, can you use a prox switch with a 1794-ID2? I need to read a prox to measure RPM, I'm having a major brain **** right...
2,483
