1794-ij2
No. That is a pure frequency counter module.
If you don't need much accuracy, you can run a sum-over-time totalizer on the frequency, but it will not be very accurate.
I currently use a 1794-IJ2 to read in a IEC 1+ (Namur) frequency signal (+24v & F Pins) and have been asked to build a similar system but using...
1,170
Hello, i'm planning to use 1794-IJ2 frequency module for the first time in my new project. My questions are: 1)can i use this module in place of...
2,792
Greetings, I'm putting a 1794-IJ2 (Frequency Input Module) in a small Flex I/O drop from a ControlLogix PLC. The user manual gives programming...
4,391
Hey Everyone, After reading a lot on this forum and elsewhere I see not many are fond of the 1794-VHSC module. I can see to a degree as I was...
178
I'm sure this question has been posted a thousand times on here but for me it was even funnier when I got to ask Rockwell / AB directly. My...
171
