19" Rack mount for PLC
gripster
Dec 2010
Londinium
40
Hi All
Need to relocate a DirectLogic 305 into a 19" rack.
So need a 3U 150mm deep tophat shaped panel. We have some in the simulator but these are over 15 years old and no record of where they came from, I can 'borrow' one from the simulator for the job but need to replace it. Any one in the UK no of a supplier? Google sadly letting me down.
Hi All
We use these, any good ?
https://www.moxa.com/product/RK-4U.htm
Hi gripster,
was going to suggest the Network Cabs ones. I bought a fair number of them last year to install our Stratix switches for our Ethernet Network.
The bigger ones are more robust, and I had to modify them to put DIN rail on the rear, and more trunking. Reasonable well made, even bought a few spares just in case, and have used them for other DIN rail applications within a 19" rack panel.
I have an Rx3i system on a 7-slot universal backplane that I want to recess mount in a 19" rack. At first glance the GE IC693ACC313 Recessed...
2,408
Hi all, Has anyone installed a ControlLogix chassis in a 19-inch server/network rack before? If so, where did you locate the equipment to do...
4,443
Is there any limitations on the maximum amount of communication cards in one rack. for example if i have a 17 slot rack with the following setup...
2,058
Hey guys... I have a couple of cabinets with ~40 Ethernet connections coming in. I found some nice rack mount style managed switches, but my...
2,951
Hello, I have been trying to figure out how to connect to and monitor a DLR that is on a remote rack from my PLC. The local has a 1756-L81E and...
122
