193 E1 Plus EtherNet/IP
nmurray
Apr 2014
USA
90
I am having a hell of a time trying to set the IP address in some of these.
I have done it in the past and it was simple.. what am I doing wrong??
I have my NIC card set to dynamic, I have opened BOOTP
I can see the mac address of my NIC card and the MAC address of the Module.
I add module to relation and give it an ip address.
The manual says to powercycle the module, then in bootP utility in the discovery it will display the IP Address next to the mac Address.. This is not happening for me..
haha, that is definitely what it seemed like. I was talking to tech connect for 1 hour doing the same thing over and over.. then it started working.. I almost wonder if its something with my PC.
In general, when you're setting up automation devices for a static IP network, you need to have your computer set for an address on that static IP network.
While the BOOTP/DHCP Utility can assign an address to a device without being on that device's network, neither the utility nor RSLinx nor anything else can communicate with the device over TCP/IP unless your computer has an address on that network. That includes sending the "Disable DHCP" command.
In general you must first use the BOOTP/DHCP utility to give an IP address to a device, and then also use the utility (or RSLinx) to disable BOOTP/DHCP. That will result in the device no longer sending out BOOTP/DHCP requests.
I prefer to use RSLinx Classic to disable BOOTP/DHCP because the Utility itself doesn't always work.
Dear sir, i am trying to use web browser to config the 193-DNENCATR Ethernet/DeviceNet interfacing to E3 (EC3) Allen Bradley electronic overload...
2,610
Hi everyone, I am currently working on a AB 193-EDN and i am trying to figure out this "Average %FLA", it keeps showing 70-75 but my clamp meter...
103
Hi all, I have an existing system with an E3+ exchanging data to an L16ER-BB1B through a 193-DNENCAT EIP/Dnet gateway. However, there is data...
431
I'm looking for some help in understanding a part number for an Allen Bradley overload. I looked on ab.com but couldn't find information on P/N...
1,664
Hi, I'm currently trying to understand this product. A customer has asked if we can incoorporate it in a system he will be offered. The system...
3,804
