1st Time PLC - Need Help
Hoegenauer
Apr 2003
Would someone be willing to help me get started.. I have a GE Fanuc Micro PLC that I need to program for the following sequence.
PB Start Button - drives a cylinder to end - activates end switch - drives home - activates home switch - drives another cylinder to end - activates end switch - returns this cylinder home - end sequence.
I was not sure how to build the sequntial logic since the two cyliders will be both at home three different times in the sequence - therefor, I cannot rely on just the switch conditions. I am sure that this is such a simple application, but I just dont see the solution..
Thanks.
Trey Hoegenauer
I suspect that all you are missing is the recongition that you are not tied down to only using your real-world devices when it comes to writing a program. What I mean is that you can (and almost always MUST) create internal flags to help you with your logic:
PB Start Button
Set Flag 1: 1st Move Started
Reset Flag 1 and
Set Flag 2: 1st Move Complete
Since Flag 2 is set
Reset Flag 2
end sequence.
The key here is that you know you don't want your second motion to occur until the first one is done. So be it. Create a flag that marks the conditon is done so you need to differentiate which is which.
Is that any help?
Steve
Sorry about having to using a G.E. PLC... just kidding
Not sure about G.E.'s nomenclature, substitute the correct terms as necessary
Xxx = Inputs
Cxx = Internal relays
Yxx = Outputs
Code:
+   Start PB                           +
+     X0                   C0          +
+----]  [----------------( SET )------ + Cycle Start
+                         CYL 1 RET    +
+     C0                    Y0         +
+----]  [-----------------( OUT )------+ Cylinder 1 retract soleniod
+  Cyl 1 end SW                        +
+     X1                     C0        +
+----]  [------------------( RST )-----+ Cylinder 1 at end limit
+                    |       C1        +
+	            +----( SET )------+ Cylinder 1
+                                      + extend to home limit
+     C1                     Y1        +
+----]  [------------------( OUT )-----+ Cylinder 1 extend soleniod
+ Cyl 1 home SW                        +
+    X2                       C1       +
+----]  [-------------------( RST )----+ Cylinder 1 at home limit
+                     |       C2       +
+                     +-----( SET )----+
+                           CYL 2 RET  +
+    C2                        Y2      +
+---]  [--------------------( OUT )----+ Cylinder 2 retract to limit
+  Cyl 2 end sw                        +
+     X3                        C2     +
+----]  [---------------------( RST )--+ Cylinder 2 at end limit
+                      |        C3     +
+                      +-----( SET )---+
+    C3                        Y3      +
+---]   [--------------------( OUT )---+ Cylinder 2 extend to home
+                                      + limit
+  Cyl 2 home SW                       +
+      X4                    C3        +
+-----]  [-----------------( RST )-----+ Cylinder 2 at home limit
                                         and Sequence end
Hope my expanding on Steve's post helps, a only one of a 101 ways to do this control.
Don't forget, There are no stops in this or safety's in this example
writing my first compact logix program which will basically duplicate a micrologix 1400 plc program and entering ladder and trying to figure out...
1,649
Hi, Can any of Siemens PLC expert please tell me; 1) Can we ever detect the first scan of the Siemen PLC whenever it RUN (either due to power...
5,599
As far as I know the UKCA mark is mandatory from 2023, and that is 9 months from now. That is not a lot of time to investigate, design, validate...
22
4,763
Hi All, I cannot seem to find a way to move a Boolean from an Arrays UDT into a DINT. I have an Array of 32 elements with a UDT data type of 4...
1,753
Stupid question i know but i know i have seen this done before and yet i cant get it to work For the preset value of a TON I want to use a tag...
1,838
