2 duty 1 standby pump with programming
akhilbharath
Jul 2016
doha
heyy guys. can you guys please help me out. plc programming in schneider plc zelio soft 2. can you guys help me out as soon as possible.??? and also can you guys explain how it works. trip and run indications are coming from plc itself. relays are not used.
i have arranged a program in zelio soft 2
but i couldnt upload it. i will send you the power and control diagram. also these 3 pumps should be working alternatively. on first run pump 1 and pump 2 should work. in the second run pump 2 and pump 3 should work. in the third run pump 3 and pump 2 should work and this cycle continues. in all these the second pump act as an assist to the first pump. i will share the power and control diagram. i am not getting the logic to do these. thats why i am stuck.
View attachment 2 Drawing2 Model (1).pdf
View attachment 3 Drawing2 Model (1).pdf
View attachment 4 Drawing2 Model (1).pdf
How about you post what you've done so far and we'll help from there
em not aware of the logic. i cudnt solve wat to do. a program having change over timer and all are there but aint getting the logic. also you know how to convert the zelio soft program to uploadable format??
i hav attached the power and control diagram. can you guys please help me out to make a plc program using schneider zeliosoft 2 software. any plc...
2,959
<P>can anybody please give me a sample ladder program/idea for 3 pump duty,1 standby operation with minimum number of timers</P>
3,291
Dear all, I am doing a PLC program for 2 duty and 1 standby pump rotation control by using Mitsubishi Q series PLC. The control sequence of the...
10,121
can anyone help me understand the basic operation of 2 duty and 2 standby Filter bed operation in STP. There will be 2 duty D1 & D2 and 2 Standby...
1,540
Dear, It is required to control / alternate the operation of the duty / standby jockey pumps in a fire pumping station and in case the duty...
2,085
