3 pump duty/1 standby
arclivin
Dec 2013
doha
18
<P>can anybody please give me a sample ladder program/idea for 3 pump duty,1 standby operation with minimum number of timers</P>
Here is a version using the LogixPro simulator. I did not have time to finish it, so there are a few instructions missing on the Input (left) side of some rungs. See if you can add the missing instructions and addresses.
Arclivin,
Most of the people on this site can write a PLC program to control 4 pumps - and can do it with no timers. However, the first thing you need to do is define what you are trying to accomplish.
Are you trying to maintain a level in a tank?
Are you trying to maintain a constant flow?
Is there another parameter that you are trying to control?
Are you trying to achieve uniform wear?
Are all the pumps identical in terms of key parameters (flow rate, hp, electrical, etc.).
Are they are pumping into/out of the same destination/source?
Is there a maximum time you want to run a pump?
Are there other criteria?
Unless you can define the key parameters, there is no point in writing a program.
i hav attached the power and control diagram. can you guys please help me out to make a plc program using schneider zeliosoft 2 software. any plc...
2,958
heyy guys. can you guys please help me out. plc programming in schneider plc zelio soft 2. can you guys help me out as soon as possible.??? and...
2,658
Dear all, I am doing a PLC program for 2 duty and 1 standby pump rotation control by using Mitsubishi Q series PLC. The control sequence of the...
10,120
Dear all Can any one share me the logic for 2 Pump Duty and 2 Pump Standby as per Running hours selection in RS Logix 5000 Rev 20?
2,050
Hello I have up to 8 pumps that, depending on demand, I'll run however many I see fit. Pressure is my setpoint and a pid and 8 inverters deal with...
3,388
