2-Hand Safety Relay with Latching
baberb
Jun 2013
Elgin, IL
Hey all, we have an application that requires a two-hand relay, but I'm wondering if there is such a thing as a safety relay with latching function.
Operator must initiate the hazardous motion (closing the jaws to pinch product) with two-hands, but when a prox is seen the output should stay on until the process is done, allowing the operator to release their hands and the jaw stays closed. When the process is done, PLC can send a reset signal to the relay, which will turn the output off
Basically a 2-hand anti-tiedown relay, but with a latching input and a reset
Is there such a thing?
You want a 2-hand safety relay with muting. Banner AT-GM-11KM is one I've used in the past. This unit would require two proxes, one PNP and one NPN, and a muting active indicator lamp.
I have an application where I should do two hand monitoring for safety. However, I have several standard inputs, and only one failsafe digital...
2,419
Can any one recommend a two hand safety relay???
2,212
I've had recent issues when dealing with supervisors about speeding up machines and processes. One thing they always bring up is: "Why does the...
4,517
Good evening. I display the step number of a SFC on a display. Sometimes, on a trip, it goes quickly through many steps and I need to prove to...
133
Hello all I have the opportunity to buy some second hand unused components, they are Siemens motor modules, a CPU, inputs and outputs. I have...
2,159
