2 or 4 or 8 channel analog multiplexer
chupa
Jan 2013
Clearwater, FL
Is there such a device to send 2 or more 4-20mA signals over a single pair cable, digitally or however it needs to a box on the other end that will split it back up to its analog form? The protocol it uses to send over the cable is irrelevant as long as the signals on the other end are intact and update at least once per second. Is there a wireless version of the same thing that will work over 300’ open air?
Wireless for the US only (because they're 900MHz):
1) Banner Engineering is a great radio for 2 (1W Performance) or 4 (DX-80 1/8W) analog I/O. It requires some amount of mapping the I/O (with Windows software) to assign which AI to which AO. AO's are active outputs, powered by the radio's 24Vdc power supply. Even the 1/8W radios will probably work at 300 feet with the 2dB antenna included with the radio.
To go more than 4 I/O points (wired-in/wired-out) requires a break-out box (DX-85) which requires some rather complex mapping procedures.
2) Phoenix Contact's two way 900MHz radio is what I call "electrician's radio". THere is no programming.
An input on module 1 at one end goes to a corresponding output on module 1 on the other end.
An input on module 2 at one end goes to a corresponding output on module 2 on the other end.
Take it out of the box, wire it to 24Vdc, wire an AI to a channel at one end, get a replicated AO on the output on the other end. AO's are loop powered, so the 24V supply that powers the radio is used to power the AO's, too. Modular I/O can be bussed one to another. Each module has up to 4 AI's or 4 AO's. Up to 8 modules or 32 I/O points.
At 300 feet, the little 1dB SS antennas will probably punch through.
Either Banner or PC does multiple updates per second.
No wired option that I'm aware of and I've kept my eyes open for such for years.
There are Modbus I/O modules with multiple AI's which could communicate over a pair of RS-485 wires to an AO module, but one of the two would have to be a dedicated Master, and I know of no I/O manufacturer who does that. All the modules are slaves, and Modbus slaves cannot talk to Modbus slaves.
Two PAC/PLC's with AI on one end, AO on the other could communicate over any number of digital protocols, but there's the cost of that 'complexity'.
The link I posted above appears to do that see link below page 4. Peer to peer.
http://www.miinet.com/Portals/0/DataSheets/NCS_Datasheet_Moore_Industries.pdf
have a look at arduino cheap but works.
i use WAGO plc for this
National instruments has devices.
search for data acquisition
Old school: Gavazzi's Dupline//Moore wiring concentrator.
Banner also do a DX70 module which doesnt need programming and is configurable for what is needed, good bit of kit, I used one for a lighthouse control system so it could be turned on remotley and the speed of the light could be altered using a VFD and 4-20ma signal
Mickey, thank you for pointing out that peer-to-peer function.
I've used other Moore Industries products but not this one; didn't recognize what it was.
In fact, I've got a project I can use a I/O Modbus slave module.
Thanks.
Dan
Thanks.
Dan
Let us know how it works out, as I have not used one myself. I have however used other products from them with great success. Their home office was just down the street from where I used to work. The boss had a real nice black Porsche parked out front.
We have a Rockwell 1734 IE8C 8 channel analog input card, but we don't know if this is sourcing or sinking. The user manual doesn't seem to have...
1,151
Good evening, just a dump question, I’ve configured channel no 13 with scalling as attached, then shown not linear reading, even when i simulate...
1,716
Good Evening , I have a 1756-IF16 Analog Input card already installed in a working ControlLogix Rack. I need to add another Analog 4-20 ma...
2,195
Hello I was needing help with the proper scaling on a Modicon TSX Quantum- AVI030-00 8 Channel Analog Input PLC card. What would be the proper...
1,498
Hello all. I have been working with an SLC 5/04 system, which houses various Digital and Analog INs and OUTs, up to Slot 29. I am currently...
2,539
