2 Q's RSview - PLC5 tag arrays?
badbadtz560
Oct 2008
GA
Please forgive me if I use the wrong vocabulary on this
I am trying to program a panelview 1250 using RSview ME, which will hook up to a PLC5 device.
Do you guys know the tag notation to have it look at .. say three bits out of a 16-bit word? Say I want to look at N78:16/3, 16/4, and 16/5.
How would I type this in to the direct tag so that it only looks at those three bits? So far the expression looks something like this:
{::[my_plc5]N78:16/3} and I tried looking at the "LSB" (least significant bit). I don't think it's working as intended though.
2) The second application would be the same as above, only that I'm trying to pull a whole number (integer?) out of 3 bits. I assume I'd do the same thing as above but have the tag look at "value" instead of "LSB"
I'm guessing you are looking for the "Bit Array" datatype which was available in earlier PanelViews? The "Bit Array" datatype is not supported in View ME. (Except as an Alarm trigger). To get the value from 3 bits, you could use an expression and some math. 4*Bit3+2*Bit2+Bit1
Somebody please advise me how can configure RS view 32 OPC server for controlNet redundancy.Since both PLC-5 controller has different controlNet...
2,086
I'm using RSVIEW ME 4.00 to program a PV+ which is communicating with a PLC5 via RIO. I've developed my application with 5 vertical sliders that I...
3,383
Any help would be appreciated. Here's the setup....RSView 4.00 with no patches installed running on a PC with XP Pro. I also have RSLogix 5 on...
3,212
Is anyone using RSView or Wonderware to set the clocks in a PLC5. If so, how?
3,586
DaMan
D
Hello fellow wirenuts, I am looking to find the P.B. touch indicator option on version 13.00 and failing. It has been a year or so since I last...
330
