1. Switch off power to the HMI device.
2. Start ProSave and select the "General" tab.
3. Select the device type and select "Ethernet" under "Connection".
4. Enter an IP address.
5. Switch to the "OS Update" tab.
6. Enable "Reset to factory settings".
An input box opens where you can enter the MAC address.
7. Go to the "MAC:" area and enter the MAC address of the HMI device.
8. Select the HMI device image file "*.img" under "Image path".
The HMI device image files can be found in the installation folder or on the product DVD of the Engineering System.
When the HMI device image file is opened successfully, information on the image version is displayed in the output area.
9. Run the operating system update with "Update OS".
10. Switch on the power supply to the HMI device.
11. Follow the instructions in ProSave.
