20-COMM-D Explicit Message Write
gmferg
Feb 2008
Modesto, CA
340
I have been using explicit MSGs to write parameters to PFlex Drive and 20-COMM-D to setup comms for DNet. These will setup Speed Ref, datalinks, etc. This saves a lot of time when commisioning hundreds of drives for a project.
Part of this setup requires that I write to params 13, 25, and 26 of the 20-COMM-D to enable datalinks. Since PFlex 70/700 drives have varying numbers of total params and the 20-COMM-D params appear after the drive params, I need to know how many total params the drive has. I can then add 13, 25, and 26 to this total param count to hit the correct 20-COMM-D params.
The following MSG setup is supposed to return the total number of drive parameters only. This works about 80% of the time. The other times, the MSG will either error out or return a number representing total number of drive params + 20-COMM-D params.
Is there a more reliable method for retrieving the total param count?
Is there a better method for writing directly to 20-COMM-D params?
I currently have a SLC 5/04 with a 1746-SDN DN interface module, there is a PF523 on the devicenet network that I want to read multiple parameters...
1,304
Guys need a bit of help getting the instance correct for a 22comme with a PF40P. Trying to get 2 things first is the drive current amp draw...
106
hi to all, have anyone tried to communicate Schneider PM800 to a ML1400 through rs485? i am having an issue with it just receiving message...
51
Hey guys. As the title suggests, I need to configure a Danfoss Aquadrive FC202 inverter, so that its logic inhibits the local command when the...
90
Hi; In a cabinet of a machine, a Fatek PLC with an Ethernet communication card is working. In the same cabinet, there is a 1 kW inverter. When...
16
575
