20 ML1400 Communication Problem
alijuda
Jan 2013
Iraq
62
Dear Friend
I needs your help with below matter
I used Cisco Managed switch 24 Port to communicate between 20 station of ML1400 PLC , I configured the Ports in Cisco switch as PC and put IP address of each PLC in same VLAN
The problem I couldn't see any PLC when I connect Via switch ? and there is no message arrived between stations , the longer distance between far station not more than 75 meter and I used Cat6 Ethernet cable
Yes , for near PLC its 0 lost and 100% good communication only far station its 3 Package received & 1 Package lost its 75% , but even for 100% send & Received I couldn't see the node in Rslinx
You will have to determine the quality of your Ethernet cabling yourself, hopefully using the port statistics features of your switch.
even for 100% send & Received I couldn't see the node in RSLinx[/QUOTE
The RSLinx Classic "EtherNet/IP" driver uses a broadcast packet to identify devices on the network. Many VLAN and VPN configurations will block this broadcast packet.
A simple test and workaround is to configured the "Ethernet Devices" driver in RSLinx Classic, which requires you to set up a table of IP addresses and connects to them directly.
I'm having an issue getting explicit messaging to work between a micrologix 1400 and Kinetix 300. IP addresses and subnets are set up and I can...
1,996
Hello, I am trying to use micrologix 1400 Ver.A as adapter and a Productivity P1-540 as scanner, only Ethernet/IP is supported by ML1400 Ver.A...
1,856
Dear Friends I have problem to communicate PV+ 600 to communicate with ML1400 through straight RS232 cable 2711-NC13 when I test my application...
1,474
Dear My Friend Iam Very thanks for all Helps in this group , I get good information from your technical supports I have 12 Protection relay type...
1,583
Hello! I would need some help on a question my customer has: He wants to communicate with our MicroLogix 1400 using Modbus and RS485. I'm not...
7,401
