2080-MOT-HSC HSCE ring counter
technolog
May 2015
Ohio
320
I'm trying to set up a ring counter - one that transitions from 3599 to 0 (and 0 to 3599 in the reverse direction). My counter insists on continuing to count up beyond 3599 instead of rolling over. It's working perfectly as a linear counter, counting up and down depending on direction. I've attached various screenshots showing the config and variable values. Can anyone spot what I'm doing wrong?
I know it's showing an error at the moment - it's the result of my latest attempt to alter the HSCE_CFG variables to get it working.
The module is in slot 2 of a 2080-LC50-48QWB.
Yeah, good luck. The Micro800 line is a hot mess, primarily because the documentation is even worse.
I think I did get ring counting to work once, but I was only counting up.
In your case, the first thing I would do is leave the quadrature can o' worms for later, and instead focus on getting ring counting working on minimal count-up-only and count-down-only applications.
I seem to have got it working. I think my main problems were that the HSCE_CFG.InitAccumulator setting cannot be the same as HSCE_CFG.OFSetting or HSCE_CFG.UFSetting and it needs to be inbetween them and also inbetween the HSCE_CFG.HPSetting and HSCE_CFG.LPSetting.
To be able to reset the accumulator to 0, I had to change the .OFSetting to 1800 and the .UFSetting to -1799. I'm not using the counter output but I set the .HPSetting & .LPSetting to nominal positive and negative values respectively.
Actually, having the counter rollover from 1800 (180.0 deg) to -1799 (-179.9 deg) (forward direction) and from -1799 to 1800 (reverse direction) is probably a more elegant solution for my application. So thanks to Rockwell for the terrible information :)
Good day, I have a micro 850 with a 2080-MOT-HSC that is being fed by two flowmeters, Schneider Electric using IMT31's as converters. They are...
459
Hello everyone. I'm having some error on the pulses read by the HSC card. I'm using the 2080_MOT-HSC as a pulse counter; in the CCW in using...
629
Hello, So I have a Micro850 PLC with a 2080-MOT-HSC Plug-In module, and i'll be using this for an encoder. I think it was version 11 in CCW...
1,990
MICRO 820 PLC - 2080 MOT HSC - Jencoder J-15S-SL Above plc, add on module and encoder are using to configure one paper cutting machine...The...
3,861
I was looking at the HSC function block in connected components and was stumped by the documentation on how to address the input for the HscID in...
3,915
