MICRO 820 PLC - 2080 MOT HSC - Jencoder J-15S-SL
Prasanth MS
Aug 2019
Tamil Nadu
Above plc, add on module and encoder are using to configure one paper cutting machine...The encoder given the value to the RA_HSC_PLUGIN functional block (accumulator) ..I am giving 20 paper cuts only first 10 or 9 or 4 only the encoder value came to the functional block acculator afterthat that the encoder value does not came ..... Depends upon the accumulator value only, we cut the paper by our user defined measurements. I download the sample code from Rockwell Automation....change the high preset values and low preset values .....I change the encoder wiring selected modes mentioned in 2080 Mot HSC manual....
From my customer side have problems about issue .I am trying to do solve the issue for 5 days .....it's not working
Kindly help to clear the problem!!!!!
I have used many of the Micros with encoder applications.
I have found that using the "HSC_Mode0" User Defined Function Block available from the Rockwell site has made it very simple to count pulses and reset that count on the fly.
I too struggled with the HSC instructions and always getting faults for configuration and such. The Mode0 instruction only has 5 input parameters and its easy. No configuration like some of the other HSC instructions.
You can also have multiple Mode0 Instructions looking at one high speed input. The first one gets HSC_ID = 0 and the second HSC_ID = 1.
Just a thought!
I tried that one.....I have got the same error....last 7 days I didn't clear that issue... First 10 sequence the value had been read after that it's not came....the same issue....I have totally upsetting about this issue...everyone questioning me why it's not working....please help me to solve this.....
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
957
Hello Everyone, Hope you all are doing well. I am new to the PLC and communication protocols used in PLC. I am currently stuck with Allen...
47
13,873
Hello how to move a new value to a timer preset PT, if possible? which of the timer parameter is , the timer current value? thanks
2,060
I'm using micro 820 2080-lc20-QBB Plc that have only one analog out 0 to 10v. I want to connect one mov that is working on 4 to 20ma. How to...
2,230
Hi All! I'm working on a project using a Micro 820 and an Ethernet/IP enabled distance sensor (linked below). Basically, all I have to do is pull...
3,443
