micro 820 plc timer
nmk34
Apr 2019
texas
80
Hello
how to move a new value to a timer preset PT, if possible?
which of the timer parameter is , the timer current value?
thanks
See this video
It seems to me that, if you duplicated the first programming, MOVing TIME values to TON_1.PT might do the trick.
It also looks like you can create a TIME tag/variable and tie it to the PT of the timer, then changing the value of that TIME tag should change the PT of the timer.
I think it is important that however you pass a value to the .PT of the timer, that value has to be TIME tag.
See also here and here.
hello
i think you can not write t .PT for micro820, i tried that. with other plcs like SLC, that works fine
Here is a working example.
In this first image, dint_pt is 1500 which the ANY_TO_TIME converts to the TIME data type variable time_pt with a value of T#1s500ms. Input 02 was toggled to 1 and TON_1 has expired after timing for 1500ms.
In this second image, state changes to inputs 00 and 01 have decremented dint_pt by 100 and incremented dint_pt by 500, respectively, so dint_pt is now 1900, which ANY_TO_TIME converts to 1s900ms as the value of time_pt. Input 02 was toggled to 0, then back to 1 so TON_1 has expired after timing for 1900ms.
The micro 820 is visible in RS Who when I configure my Ethernet to capture the random IP. I am getting an error when following the steps below...
963
Hello Everyone, Hope you all are doing well. I am new to the PLC and communication protocols used in PLC. I am currently stuck with Allen...
47
13,892
MICRO 820 PLC - 2080 MOT HSC - Jencoder J-15S-SL Above plc, add on module and encoder are using to configure one paper cutting machine...The...
3,875
I'm using micro 820 2080-lc20-QBB Plc that have only one analog out 0 to 10v. I want to connect one mov that is working on 4 to 20ma. How to...
2,236
Hi All! I'm working on a project using a Micro 820 and an Ethernet/IP enabled distance sensor (linked below). Basically, all I have to do is pull...
3,447
