Allen Bradley Micro 820 PLC
I'm not 100% sure, I don't use unconnected sends like this. You could try adding the pad byte back in and the route path size byte, with a value of 0.
Hi dmroeder,
I tried to add pad byte and kept route path size value as 0. I am getting connection failure in the response from the PLC.
Please find attached screenshot for reference. Addition Status 0x0205 is received in the response. Please let me know if you have ever faced this problem.
Hi dmroeder,
Can you please let me know if pylogix driver supports access to array datatype with Micro 800 series PLC ? I wanted to capture the packet structure used for array access.
This unit was removed from one project where it had perfomed nicely. Wired into simulator and we have no signs of life no LED,s lit power...
945
Hi all, I have problem that I could do with some help with: I have a setup consisting of an Allen Bradley Micro 820 controller, Panelview 800 and...
3,062
I have an allen Bradley micro running a fan in an industrial paint mixing facility. The input fuse is 3a. The system will run fine for a bit and...
1,990
Found a couple of old unused Micro 810s with lcd displays in the miscellaneous section. Don't ever use ccw or indeed any Allen Bradley, but...
4,167
Hi guys, I need to add 2 x 1769-IF4 and 1 x 1769 OW16 output card into an existing Micro 1400 Series A PLC. It has already has 3 expansion...
2,840
