Hi all, I have problem that I could do with some help with:
I have a setup consisting of an Allen Bradley Micro 820 controller, Panelview 800 and a VSD, all communicating on a private Ethernet IP subnet as an island.
The above setup is part of a mobile machine that is able to be moved around our company.
What I would like to achieve is to add a network device that is able to bridge / route between the private machine and plant level networks. I would like this to happen by having the plant level network DHCP server assign one single dynamic IP to the bridge / routing device.
Essentially what I want is a setup that works akin to a Compactlogix 5380 configured in Dual IP mode (one port for the machine network and one for the plant network).
The end goal would be to be able to move the machine between different sites / subnets on our company, with the ability for it to be plugged in to the local subnet, if needed, mainly for support purposes. It would also be useful to be able to see the assigned dynamic IP somewhere on the HMI.
Any ideas greatly appreciated!
Many thanks,
Fred
Many thanks,
Fred
